54 wiper motor seal? - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Is there supposed to be any kind of gasket or seal between the motor and firewall? I dont remember back 20 years when I removed it. Go figure. Thanks again! Also, are some of the firewall grommets that come from CC required to be drilled to fit certain size penetrations?
  • Eric F.
    • June 30, 2003
    • 319
    Re: 54 wiper motor seal?
    Guy, There wasn't a gasket or seal on the one I just removed, only the metal mounting bracket was between the motor and the firewall. and there wasn't anything between the mounting plate and the body. I've attached a pic. Eric IMG_0102.jpg
    • Chris S.
      • January 1, 2000
      • 1064
      there is no gasket between the motor and the 'glass
      the grommets should fit in their holes with no issues......
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 499
        Thanks guys, thats what I needed to know!
        • Troy P.
          • February 1, 1989
          • 1279
          Eric, your's has previously been removed as the mounting plate is painted. Looks like someone repainted your engine compartment blackout.
          Seems to me there is a rubber insulator strip between the tang on the back of the motor and the engagement of the pulley on mounting plate to avoid metal to metal contact between those two moving parts.
          • Eric F.
            • June 30, 2003
            • 319
            Yes, I'm aware it has been repainted but the mounting plate didn't appear to have been removed and there wasn't a seal between it and the fiberglass when I removed it. I don't recall seeing an insulator between the motor and plate but it could have been there. There wasn't one between the motor and plate on my 56 caddy either.
            • Chris S.
              • January 1, 2000
              • 1064
              there is a small cardboard insulator between the the motor and the plate - shaped like the tang ....rectangle....
