Hello everyone,
I put my firewall insulation in this weekend and I had to remove the Brake and Clutch bracket assymbly to put the glue in upper insulation on. I then installed the lower insulation with the black backing and the push in plugs. Then I installed the brake and clutch pedal assymbly and sandwiched the lower insulation between the pedal bracket and the firewall. I did this because the insulation had cutouts in it for the 4 studs to go through and I figured that if it was supposed to go on top of the bracket than there would not be cutouts or there would be a square cut out that the whole bracket would fit though. Then today I found the old lower insulation that I removed remnants of and it looks like it was not mounted between the bracket and the firewall. Does anyone know what was installed first? The lower insulation or the pedal bracket assymbly?
Thanks in advance,
Bill
Thanks in advance,
Bill
