I reassembled the steering column and reinstalled the steering wheel hub, horn switch, etc. The horn will not work after replacing the turn signal canceling cam. The horn contact plunger does or is not protruding out far enough to make contact with the horn button contact foot. Is there a possibility that I put the spring loaded plunger in backwards? Everything work prior to replacing the canceling cam. This a non telescopic column.
Any comments would be greatly appreciated.
thanks,
James West
thanks,
James West
