68 ignition cylinder removal - NCRS Discussion Boards
  • Jeff P.
    • 797
    I bought the tool. Lefty loosey righty tighty right? Turn counter clockwise no problem till I come close to the end. I didn't try to force it. The small hole on the facia. Do I have to stick in say a paper clip to release it? Many thanks as always.
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 68 ignition cylinder removal
    Jeff. I use a paper clip and stick it in the hole and turn the switch it to the right I believe. It should come right out.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    • Jeff P.
      • October 21, 2011
      • 287
      I thought you put the key in and turn to acc position an then put the paper clip in the hole and it releases the cylinder. Been along time since i changed one.
      • Jeff P.
        • 797
        Thank you jack and Jeff. The outside ring that screws on to hold the switch in place has four notches in it. I bought the tool to take the ring off. I get to a point where I can't loosen it any more. I don't want to force it. Any thoughts?
        • Jeff P.
          • October 21, 2011
          • 287
          Jeff did you take the cylinder out first ? Possibaly the nut is stopped because the cyl. is binding the nut. just a thought.
          • Jeff P.
            • 797
            Thank you. The cylinder had to come out first before you can take the ring off. Yes Jeff the key has to be in acc. To pull out. Thanks, guys another baby step to resto heaven.
            • Jeff P.
              • October 21, 2011
              • 287
              Jeff just to shift gears to another topic; do you know how long the return line rubber hose is, at the bottom by the fuel pump? This would be the section of rubber fuel hose where the two metal return lines come together.
              • Jeff P.
                • 797
                I will be glad to check Jeff. The 68 coupe is up on the lift.( leaky radiator ). Ill get back.
                • Jeff P.
                  • 797
                  Jeff ,is this the hose your talking about?
                  • Jeff P.
                    • October 21, 2011
                    • 287
                    no i need a top view of the small diameter line from the fuel filter down to the fuel line on the frame. the rubber is the piecce i need.
                    • Jeff P.
                      • 797
                      Ok,I'll get back
                      • Jeff P.
                        • 797
                        Jeff,I measured 10 1/8 inches.
                        • Jeff P.
                          • October 21, 2011
                          • 287
                          Thanks for this information Jeff.
