installing the water pump belt on a 66 427 with a/c and ps - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    having a hard time finding a thread that covers the belt installation and belt size for my 66 427 w a/c & ps water pump. thanks for any instructions, Dutch
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: installing the water pump belt on a 66 427 with a/c and ps
    Harry,
    If your belt go's from the bottom pulley, and only to the water pump pulley, W/O adjustment, then the water pump pulley needs to be loosned or off.
    Then put the belt on the bottom pulley and over the water pump pulley and push the water pump pulley over the center shaft and tighten the pulley.
    That's how my 67 is done and not sure if the 66 was the same BUT the book calls it "the water pump pulley" and that is the only funtion of the belt.
    As far as size, I ordered mine and it fit just fine with the right tension.
    DOM
    • Harry L.
      • December 22, 2008
      • 370
      that is my question, how does one tighten the pulley? Do you take the crankshaft pulley off and tighten the pulley somehow? thanks, Dutch
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Harry,
        As Dom said, you MUST remove either the WP or Crank pulley to remove or install the belt. I prefer the WP myself, easier to reach. There is no adjustment for the belt, just enough tension by design to turn the WP. Provided of course you have the correct belt. See below.
        Much info here too about slight variations of the belt lengths available today.....
        https://www.forums.ncrs.org/showthre...ht=belt+pulley
        and a solo thread of mine with more.....
        Note also, that if the WP pulley is a reproduction it WILL have an effect on which belt version is used(ie short or long), as I found out the hard way. On a '67 BB I replaced a (wobbly!) NEW repro WP pulley with a NOS pulley and had to change the belt again. I forget which I used but we kept both around for spares. BTW the vendor that makes the pulley admitted 2 years ago that their pulleys were wobbly.
        Rich
        edit, Harry, with AC the belt is GM# 3889374 so maybe this application doesn't have a SV & LV. Quanta link shows one version...
