Re: Question about cylinder heads to the engine guru's
Actually the question regarding close vs wide ratio in a drag car has an added component, and that is how much tire/Traction are you dealing with at launch. In My Dragracing days, we had both close ratio 2.20 low boxes and 2,54 (close ratio (special gearset with evenly spaced drops between gears) and the high $$ trans did not help much as we were running a bigblock on a 10 inch tire limit class. How much tire you are running as well as overall weight distribution are big contributors to the "right" answer to the trans.
If I wanted to cheat, I could always use these guys, they are local to me
