Fuel Pump Install - NCRS Discussion Boards
Fuel Pump Install
  • Jeff P.
    • 797
    Fuel Pump Install
    It's been a while ,so I learn. Any method of stopping gas flow would be of help. I thought it would eventually stop but it "keeps on comin". Thanks, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Kent S.
    • February 1, 1993
    • 203
    Re: Fuel Pump Install
    Just did this on my '63. Needle-nose vise grips with some padding - clamped it back by the gas tank, so there was some gas from the line when I removed the line at the pump, but not much (could have clamped it at the pump, but things are pretty tight in that area). As you've discovered, if you don't clamp it someplace, you'll empty the tank when you disconnect the hose.
      • 43193
      Kent and Jeff-----
      Yes, the bottom of the tank in every 1963-74 Corvette is higher than the fuel line so if the line is open at any point, the fuel will just gravity flow until the tank is empty. The same thing will happen if the diaphragm in the fuel pump fails.
      • Daniel S.
        • February 1, 2000
        • 164
        Hose clamp around a bolt that is the same ID as the fuel line should do the trick
        • Jeff P.
          • 797
          Thanks, guys
          • Steven B.
            • June 30, 1982
            • 3976
            This is a good method I use. Also used a cork once.
              • 15573
              Just push an old spark plug into the hose, or a new one -- doesn't matter. Works for me.
                I use a pair of plastic slide-locking pliers with rounded jaws made specifically for stopping flow in 3/8" rubber fuel lines without damaging them - most FLAPS have them.
                • Paul J.
                  • September 9, 2008
                  • 2091
                  I have a couple of jars of plastic and rubber plugs, these came in open ports of new and reconditioned parts. I just hunt for one that fits and plug the flow.
                  • Jim L.
                    • September 30, 1979
                    • 1805
                    My solution is to install a shut-off valve back near the tank. This makes it trivial to work on the pump or any portion of the fuel line ahead of the valve.
                    Jim
