I would like try to use a stock 64 Pulley set up (with Power steering) on my engine which is a 68 327 (CE block).
Got 3744043 crank pulley and 3790356 water pump pulleys as called for but the first problem is the crank pulley is back too far (about 1/8 ") behind the WP pulley. I did some checking and verified I have the fourth design Harmonic balancer (66-69) that is 6 3/4" in diameter with crankshaft drilled for a center bolt. I realize the original 64 design was a riveted 6" balancer but was wondering if anyone could tell me if the depth is the same or more. Either way I am 1/8" too far back at the crank using 64 pulleys and would not be able to use the front position for the alternator as original which is what I am trying to achieve.
I was (up to this point) running the deep groove pulleys 37766987 crank and 3770245 WP with this engine using the inner (Rear) groove for the Alternator and outer for P/S and all was pretty well aligned.
One last question, will the early style P/S pulley 3770509 interchange with the later slotted one if the pump has a nut holding the pulley?
Has anyone come accross this that can point me in the right direction. Could not find any info on this in the archives.
Thanks in advance for any help here.
Dan
Dan
thanks so much for your efforts. Regards, Dan
