I have read some of the threads giving good explanations of the VISUAL differences between the shorter Corvette generator end frames on the 043 Delco units, but my question is does the size (height) difference on the commonly found passenger ones (1/4" taller) make a difference in any way relative to the alignment of the generator assuming you are using the correct fan and brackets ect??
If both the front and the rear passenger frames are the same height relatively, can we conclude they should function the same as the Corvette ones but just not appear correctly for judging??
TIA for your replies. Dan
