1972 ignition Key Warning Buzzer Switch - NCRS Discussion Boards
  • Glen C.
    • July 15, 2009
    • 216
    I can't seem to locate this switch for a standard column. Would anyone know if it's available and a source?
    Glen
    Re: 1972 ignition Key Warning Buzzer Switch
    Glen
    Glen------
    The switch, GM #7804414, was discontinued a few years ago. However, I believe it's now available in reproduction. I suppose that most of the usual reproduction sources would have it.
    • Jim S.
      • August 31, 2001
      • 730
      For years the key warning switch was available for the standard column but not the T&T. Now the T&T switch has been reproduced and the standard switch is no longer available. I have tried looking for the part on several sites, with no luck. (Locating electrical parts on most supplier sites is no fun.) I know it was available for years so there still might be parts in bins, shelves, etc.
      Jim
      • Glen C.
        • July 15, 2009
        • 216
        Thanks Joe and Jim. I haven't been able to spot it in a catalog but I'll keep digging and make some calls. The buzzing is getting annoying.
        Thanks again,
        Glen
        • Bill C.
          • July 15, 2007
          • 904
          might be worth giving Doc Rebuild a call ..
          he seems to have all kinds of things no one else does..
            Bill and Glen------
            Yes, that's an excellent suggestion. The Dr. Rebuild part number is 2187406
            • Jim S.
              • August 31, 2001
              • 730
              I just got my Paragon Reproductions catalogue today. 14756 1969-76 Ignition key warning switch, all w/o tilt & telescopic. Replacement style.
              The bad news is that it says to CALL. 1-800-882-4688
              • Glen C.
                • July 15, 2009
                • 216
                Jim,
                Thanks. I called both them and Doc yesterday and the switch was out of stock and doesn't look as if will be available again. Paragon suggested watching eBay which I will do.
                Have a great weekend
                Glen
                • Glen C.
                  • July 15, 2009
                  • 216
                  Bill and Joe,
                  Spoke with Doc and it's out of stock and not available. Thanks for the lead.
                  Have a great weekend,
                  Glen
                  • Jim S.
                    • August 31, 2001
                    • 730
                    Glen,
                    I found a used switch today. It appears good. It does not have the spring with it however.
                    eMail or PM me if you still need it.
                    Jim Shea
                    • Richard C.
                      • July 31, 2001
                      • 144
                      Glen, I have a good used one for a 69, i think they are the same. 615-255-3939. richard
