1972 Wire ID help - NCRS Discussion Boards
1972 Wire ID help
  • Glen C.
    • July 15, 2009
    • 216
    1972 Wire ID help
    I"m slowing working my way through wiring clean-up and I have this single tan wire that I can't id. It seems to originate towards the center of the fire wall. Would anyone know what this goes to? Any help would be greatly appreciated.
    Glen
  • Bill C.
    • July 15, 2007
    • 904
    Re: 1972 Wire ID help
    pretty sure that is the idle solenoid wire.
    my 72 BB had that wire coming out from the TCS harness.
    • Larry M.
      • December 1, 1986
      • 541
      I agree with Bill. My 72 small block has the same color wire, and same type wire connector, going to the carburetor solenoid.
      • Don L.
        • August 31, 2005
        • 1005
        Yep. For sure, Bill and Lawrence have nailed it. The wire is supposed to run to the solenoid, held against the inboard edge of the LH rocker cover.
        Hope this helps.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Glen C.
          • July 15, 2009
          • 216
          Thanks everyone. I'll get it sorted out now that I know what it is.
          Glen
          • Don L.
            • August 31, 2005
            • 1005
            Glen, saw your last post this morning and remembered I had some pics of my engine without air cleaner can on it. It shows the tan wire's routing. I assume it's TFP, since the car's been judged several times this way, however, if someone sees something out of order, please let me know. Hope this helps.
            Don Lowe
            NCRS #44382
            Carolinas Chapter
            • James B.
              • March 1, 1985
              • 217
              That's one nice looking engine compartment, Don!
              • Glen C.
                • July 15, 2009
                • 216
                Thanks Don. That is a great looking engine compartment for sure. It appears that one of my previous owners has removed the solenoid. The fellow I bought my car from had the engine rebuilt and I got boxes of all the old parts he removed. I hope it's in one of them. I'll check today.
                Again thanks for the photo it helps a lot,
                Glen
                • Glen C.
                  • July 15, 2009
                  • 216
                  Don,
                  I dug through the boxes of replaced parts that came with my car and found the solenoid. The previous owner rebuilt the engine so I guess he just removed it. I think it's original as it looks a bit worse for wear. Is there a method to test it operation prior to re-installing it?
                  Glen
                  • Dan A.
                    • February 1, 2004
                    • 212
                    I simply grounded the body of the solenoid and put 12 volts to the male power connector to verify mine operated. I believe the tan wire should have 12 volts when the ignition key is on.
                    • Don L.
                      • August 31, 2005
                      • 1005
                      I agree with Dan. This is how I tested mine too. Hope this helps.
                      Don Lowe
                      NCRS #44382
                      Carolinas Chapter
