54 lower trunk lock mechanism worn - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Mine is worn out it seems. I dont trust closing the trunk as I might not get it open. Anyone have a good one they would part with??? The lobe is worn and Dote really think something like that is repairable, pot metal. Thanks anyway!!!
  • Troy P.
    • February 1, 1989
    • 1279
    Re: 54 lower trunk lock mechinisiam worn
    I've got a spare but might need it. I bought it advedrtised as a supposed passenger car part that looked awful close to the Corvette part to me, going by memory. But the Corvette parts book indicates the lock mechanism was a Corvette only part.
    While the pot metal part is not repairable you could disassemble the mechanism and make a steel part to replace it. I never could figure out why it was pot metal. Probably cheaper to mold the part than to shape it any other way.
    In the meantime you might take the key cylinder out and use a bladed screw driver to unlock it. As I recall the screw driver can turn it farther than the tang on the keyed cylinder can. Sometimes you need that extra bit of rotation to get it to release.
    • Chris S.
      • January 1, 2000
      • 1064
      it is grooved ?
      they can be removed.
      try build up of epoxy or another 2k material.
      Just a thought....
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 499
        Thanks guys, I might try to seperate the lobe, there is a spot welded flange that holds the lobe into place, the round portion that resides in the flange is more of the issue, that's what holds the lobe in place. Grossmuller didnt have one, Ill just have to wait it out to find a good one. Ill do the screwdriver thing for now. Once again, I appreciate all the help over the years. Body and chassis are together once again and looking nice. Looks weird seeing a body on it.
        • Chris S.
          • January 1, 2000
          • 1064
          The lobe is pot and the bracket is steel....weird.
          They dont work the greatest
          my only thought would be to try to build up the rounded part.
          If you knew a good machinst - I am sure he could machine one out of steel.....
          • Guy M.
            • November 1, 1993
            • 499
            Thanks Chris. Anyone know what the lobe dimension was to begin with, If I have that maybe I can get one machined and make some extras.
            • Jerry P.
              • September 30, 1989
              • 85
              I think I saw one on Mary Jo's web site....
