Got a leaf spring liner kit from Corvette Central and it has the stainless tip on the third (shortest) liner. Should I remove this tip prior to assembling the spring?
C1 leaf spring tip question
Re: C1 leaf spring tip question
All of the unrestored 53-55 cars I've inspected did not have that tip. That includes cars with as little mileage as 2331. I've also been under two 57 survivors and the photos I took show no tip on their short liner either.
But I've heard the theory that for some reason as the spring flexes that tip gets pushed off.
A good question I can't answer would be, "Why would it not have a tip like the others?"
Obviously I did not answer your question. Hopefully the info I have provided eventually leads you to the answer.- Top
Thanks for sharing your expertise and insight Troy. The JM says tips on only the two top liners so I will probably go with that.All of the unrestored 53-55 cars I've inspected did not have that tip. That includes cars with as little mileage as 2331. I've also been under two 57 survivors and the photos I took show no tip on their short liner either.
Obviously I did not answer your question. Hopefully the info I have provided eventually leads you to the answer.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
2013 427 Convertible
Shade tree mechanic and
B-52 pilot extraordinaire
Thanks for that Joe. That confirms my thoughts. I will remove the tips from the short liner prior to banding.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
If the clips are made like the original clips, they will have two rows of tiny teeth that bite into the liner. If present, the teeth will prevent you from pulling them off easily. You may have to use a cut off disk on a dremel tool and cut down the center of the length of the clip, then pull the two sides away from the liner. Good luck.- Top
