I am starting the rebuild of the drive train and the first part to go on the frame is the rear cross member. I bought two cross member bushings from Paragon and before I installed them in the cross member I tried the fit of the bushings on the frame. The bushings have some small play in them and it bothers me. When I took the cross member off the frame I had to use a 6' pry bar. Will these bushings compress somehow when installed or are the bushings the wrong fit and I need to find others?
69 cross member bushings
Tags: None
- Top
Re: 69 cross member bushings
Richard,
Could it be the new bushing is not tightened down far enough to the sombrero, it's supposed to be a interference fit and I think it's tapered.- Top
I haven't installed it yet. Just dry fit. so it is not tightened down. But when "dry fit" it bottomed on the sombrero and still had some play from side to side.- Top
Richard -
When the bushings have 1400# of weight on them, there won't be any play.- Top
I am probably just overly paranoid. Installation will commence. Thanks John.- Top
