Folks:
During leaf spring removal yesterday, I found the bottom leaf broken right in half at the point where the retaining bolt goes through.
1. Is it possible to just replace that one leaf?
2. If not, can someone recommend a place for purchasing a new leaf spring that is NCRS correct?
3. If I replace the leaf spring, will that make the car sit too high in back if I don't also replace the front springs? (I assume the spring constant for a new leaf spring will be higher than the old).
Thanks in advance.
Roger
Thanks in advance.
Roger
