I'm working on getting my Operations/PV Cold Start checks dialed in on my 1965 Corvette equipped with a 396 engine. Once the engine starts I've gotten the cold start fast idle dialed in at approximately 1,800 to 2,000 RPM and the hot idle curb idle set at 850 to 900 RPM based on the NCRS Performance Verification guidelines.
The problem that I am having is getting the car to start and stay running initially when cold. Per the supplemental 1965 396 chassis service manual I have the initial timing set at approximately 9 degrees; the manuals states that 10 degrees is the nominal setting with a range of 8 t o14 degrees. The choke is set at 3 to 4 notches lean. I've tried depressing the accelerator fully to the floor thinking it needed a bigger shot of fuel and also tried just barely depressing the throttle enough to get the fast idle cam up to the top step per the manual. The car will start but runs rough for about 5 to 10 seconds and then stalls. The only thing that seems to help is to have my helper hold the choke plate open until the engine starts and when it does it runs rough and requires that I feather the throttle until it smooths out at about 1,400 to 1,500 RPM and then escalates up to around 1,800 to 2,000 RPM.
When the car is up to operating temperature and then shut off I have attempted a hot restart without any manipulation of the throttle. The car does not want to start unless I feather the throttle a little until it starts. I want the car to start when hot without touching the throttle. I have not adjusted the carb idle circuits on the metering block for best curb idle based on vacuum yet.
Question: Should I go a notch or two leaner on the choke setting?
Question: Would bumping the initial timing up a few more degrees help both the cold and hot starts?
Question: Should I adjust the hot curb idle circuits now or wait until I get the timing set so the car will start and run when cold?
The carb was recently rebuilt by Bob Kuntz and ran on his engine stand before being sent back to me. The spark plugs in the car are AC Delco R45XLS gapped per the manual and I'm running 110 octane racing fuel.
What should I be looking for to get these issues resolved? Any advice would be greatly appreciated.
Thanks in advance.
James West
Thanks in advance.
James West
