Hello all. I'm finishing up an order , but I'm stuck on the spare tire mount location. One cool feature is that it can be recessed into the middle of the floor. I'm going to have a raised track to accommodate the driver door to open full. I still would not think that I'd have enough height to get the tire out with a car in there. I could always lay it on the floor after loading. Another question would be does anyone know where to get a raised track besides having one made.
Haulmark Trailer Order Question
Re: Haulmark Trailer Order Question
Jeff,
My American Hauler trailer side door opens low enough to clear the door of my corvettes. I just requested it be low enough to clear, no "raised track" necessary. The inner wheel well is about an inch below the door opening too. The American Hauler is very popular in our area.- Top
Same here Gene, my Trailex works well that way too, the spare is mounted on the inside wall in front of the car location.Jeff,
My American Hauler trailer side door opens low enough to clear the door of my corvettes. I just requested it be low enough to clear, no "raised track" necessary. The inner wheel well is about an inch below the door opening too. The American Hauler is very popular in our area.Attached FilesBig Tanks In the High Mountains of New Mexico- Top
My son has a trailer with the spare in the floor... If he gets a flat, then he can just roll the car back to clear the tire well. One draw back of an in floor wheel well is the well hangs beneath the frame work and under certain conditions could rub on the ground,
as in going over a hump into a gas station. I have my spare mounted vertical inside the trailer...easy access when needed.
Attached Files- Top
