54 Door Jambs - NCRS Discussion Boards
54 Door Jambs
  • Eric F.
    • June 30, 2003
    • 319
    54 Door Jambs
    There are two distinctly different door jambs on this car. Has anyone seen this on an un-restored car? I'm trying to determine if I need to create a defined edge on the passenger side, eliminate the defined edge on the driver side or just leave them alone. I know they were hand made in 54 but I find it hard to believe they left the factory like this.
    Eric
  • Cathy S.
    • August 31, 2003
    • 293
    Re: 54 Door Jambs
    Mine was an unrestored late 54. NO defined edge.
    • Eric F.
      • June 30, 2003
      • 319
      Re: 54 Door Jambs
      Thanks Cathy. Maybe the undefined edge should have been smoothed before leaving the factory.
      • Chris S.
        • January 1, 2000
        • 1064
        Re: 54 Door Jambs
        I would keep striping paint and primer off - was a 1/4 put on that car ?
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Eric F.
          • June 30, 2003
          • 319
          Re: 54 Door Jambs
          I haven't found any serious or major damage on the car; just a few minor dings/gouges in the exterior body. The jambs are just unusual. Chris, which photo that I posted matches the jambs on your car?
          • John L.
            • February 1, 2005
            • 207
            Re: 54 Door Jambs
            I am restoring 54 #66 .... here are snapshots of the driver and passenger side jabs from my car. Currently I am stripping the paint and have found no damage/replacement to the quarter panels but as you can see I have not stripped the jambs yet.
            Good Luck!
            John
            • Eric F.
              • June 30, 2003
              • 319
              Re: 54 Door Jambs
              John, Thanks for posting the photos. Obviously there are defined edges and I also noticed there are cutouts on both jambs for the striker plate.
              • Chuck W.
                • May 31, 2002
                • 257
                Re: 54 Door Jambs
                Here are the jams on original paint 1690....http://ckautollc.phanfare.com/493056...geID=116804877
                • Chris S.
                  • January 1, 2000
                  • 1064
                  Re: 54 Door Jambs
                  Attached is the jam of 1954 #3803 - press molded St Louis car...and I attached the jam of 1953 #201 - hand laid jig - Flint car.....You can really see the difference.
                  • Eric F.
                    • June 30, 2003
                    • 319
                    Re: 54 Door Jambs
                    Thanks to each of you for your contributions. It's hard to say for sure but I suspect the passenger jamb on this car has been reworked. I'll dig deeper and let you know if I discover body filler not similar with the time of manufacture.
                    Eric
