Just got done from draining old gas out of a 94 Camaro LT1. Had to run the fuel pump
w/o engine running. This can be done with the "fuel pump prime connector". Had to use
small alligator clip which did not work to well. Below is a picture of the connector and
I guessing the Corvettes had a similar setup. Does anybody know anything about this
GM connector? It looks to be some type of small spade connector. Does Kent-Moore
or anybody else have a test lead that would hook-up to this connector? Have never seen
one like this. Any Idea's? Please Comment. Larry
