65 headlight motor gearbox lubrication - NCRS Discussion Boards
  • Dennis M.
    Infrequent User
    • November 1, 1999
    • 6
    Replaced the pot metal gear in each motor gearbox assy. The lube that was there was a translucent light grease. Can't find any reference to what is used to lubricate these gears. Any help appreciated.
  • James W.
    • December 1, 1990
    • 2640
    Re: 65 headlight motor gearbox lubrication
    Dennis,
    Dennis,
    I use white lithium grease that you can by at NAPA.
    James West
      • 15610
      There was a thread about this very same subject about a week ago. Do yourself and favor...
      • Gary C.
        Administrator
        • October 1, 1982
        • 17549
        Dennis,
        Just recently re-lubed my '64 headlight motors. Dave and Chuck Anderson, fellow Texas Chapter members and Corvette Restorers recommended using CRC SL3331 Sta-Lube Engine Assembly Lube with moly graphite. http://www.crcindustries.com/ei/prod...aspx?id=SL3331
        The Anderson's use that grease in all the headlight motors they rebuild and it works great and doesn't gum up.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
