67 Distributor lead wire
Re: 67 Distributor lead wire
NAPA offers one and you should also install the ground wire repair kit because the solder joint on the breaker plate will eventually fail. Like most of these electrical parts for old cars, they are likely made by a single vendor, but available in a half a dozen or more "brands", so you can cross reference to any brand once you have a part number for one brand.
Chances are what you got is just the generic part at an inflated price.
I don't know the lengths, but the data is on the NAPA Web site.
If you can find a proper appearing terminal, you can shorten the wire and with a little practice with a common crimping tool nearly duplicate the OE crimp. Decades ago you could buy these OE style terminals from Delco, but I dont know of a current source.
You might also be able to undo the crimp, shorten the wire, and recrimp the terminal. I've done this with some success. The recrimp is not perfect, but it might fool some judges.
Duke- Top
