Just finished removing the old trailing arms (with a sawzall) on my '72 body off chassis restore project. I noticed two holes on the top side of the trailing arms on either side of the access hole to the leaf spring bolt (top left pic). A couple of years ago I ran across a couple of trailing arms from possible '75 or newer cars and picked them up just in case I needed them in the future. One of those arms had the same holes however slightly larger diameter (top right pic). The other one had no holes. Question: What were those holes originally placed there for and will this aspect be taken into account in futire judging if I use one or both of the newer trailing arms?
Maybe more importantly, check on the condition of the original trailing arms (top left pic above) and the pic below. Does the condition of these warrant replacement? There is some fairly heavy rust/pitting issues on the originals.
