My 63 vett front end is at different heights. The left side (driver side) is 28 inches high measured at the center of wheel to underside of lip on fender, the right side is 26 inches - according to the corvette spec's, 26 inches is the correct heights, so the left side is 2 inchs too high. I plan on ordering a set of new springs to correct this problem, however, I'm reaching out to all NCRS members to ask for their expert advise to see if they may have encountered a similar problem? I bought the car as a frame off restoration, so I don't know if the springs installed are a new match set or just a mix or if they are seated properly, of if there is a frame to chassie install issue? 2 inches in my opinion is quite a lot. Please advise
