In this thread,
https://www.forums.ncrs.org/showthre...433#post678433
I show a Dewitt's TT purchased several years ago for a '60. According to info in my brain from Noland's book, the Spec guide, and Tom Dewitt's website, 1960 had 3 versions of the 3147516 aluminum radiator.....
1- Flat tank
2- Ribbed tank (5 ribs)
3- Ribbed tank (5 ribs) with sight plug
The part# for 1960 should be 3147516.
The part# for 1961 should be 3151116. (to apx vin 1700, then they switch to non TT using the expansion tank)
This one I have is a #3 type listed above, but has a Harrison plate is stamped 3151116 with a 60E date.(May 1960). Car is a June 23, built 1960.
Is this right church, wrong pew scenario? I think I have the correct rad but the plate should read "3147516 60E".
Opinions?
Rich
p.s. I'm so embarrassed but I have to tell you what happened yesterday while installing this radiator.....
I'm getting the fan shroud bolts lined up to get the whole shebang installed. I got the right top bolt finger tight, go to the left top. It's off a bit. Okay, simple, insert a small phillips in the top hole from the back, pry it up a little to line up the 2nd hole. I hear a loud POP, like the screwdriver slipped. I then see this object flying in the air above and in front of me. It was the top threaded insert in the side bracket. It's steel. I spent an hour looking all around for it, eyeballing all the nooks & crannies, magnets in the carbs, etc(I had a towel on the carbs but used it to cover the fender!). I never heard it hit anything. Frustrated after raising the car, looking all around the garage, inside every corner of the engine, rag boxes, under tables, even down inside the open rad fill hole, I gave up. Wife came in to help. She lost her diamond from her ring years ago after vacuuming. She found it later in the bottom shelf of the fridge door! I thought she'd be the one to find it. I go under the car and start banging things with my fist. Got to the right splash shield.......ting, ting! Hit again, and nothing. Darn, maybe it was the loose battery cable clamp. Nope. Different sound. Raise the car and not on the shield. Wife reaches up above the frame. She found it! Lodged between the top frame and the brake line. Good work! Now happy. Reinstalled the insert to the bracket and pulled it back in with the bolt. Finished the install after grinding the (repro)rad support holes a little. Everything lined up now. She made a nice dinner to boot and we laughed about it. Thanks wifey!
1- Flat tank
Opinions?
Rich
