I have a question about knock-off wheels for anyone who knows about them. I'm considering putting a set on my 65 because I'm not that wild about the OEM hubcaps, in fact, I think they are rather ugly compared to the 66 hubcaps. I ran across a guy who has a set of new OEM knock-off wheels and these are the real deal as I understand it. If I understand correctly, there is an adapter that bolts to the hub assy with 5 lug bolts and this adapter has the center spindle that the wheel mounts to by way of the threaded spinner. The aftermarket replica is a direct bolt with the 5 lugs just like most modern day wheels ??????? SO, if these OEM wheels are the correct color ( which is my next question ) and they are in near perfect condition, what are they worth ? Is the color between the fins supposed to be black or dark gray ? Center hubs are supposed to be chrome, right ? Last question, are they trustworthy or should I go with the aftermarket direct bolt version ? JC
knock-off wheels
Re: knock-off wheels
originality is everything I would keep your wheels if they are original to the car you would have points deducted if not original. real knock offs were not avail until 64 and later. if your build sheet shows that option I would change them to match? real knock offs need an adapter that has 10 holes the orginals were made by Kelsey hays then western wheel and so on they are grey ,hubs chrome and spindles have specific colors and markings that show the direction to remove them. don't forget the spare too?- Top
...If I understand correctly, there is an adapter that bolts to the hub assy with 5 lug bolts and this adapter has the center spindle that the wheel mounts to by way of the threaded spinner. The aftermarket replica is a direct bolt with the 5 lugs just like most modern day wheels ???????... SO, if these OEM wheels are the correct color ( which is my next question ) and they are in near perfect condition, what are they worth ? Is the color between the fins supposed to be black or dark gray ? Center hubs are supposed to be chrome, right ? Last question, are they trustworthy or should I go with the aftermarket direct bolt version ? JC
There is nothing wrong with the quality of reproduction knock offs. The only complaints that I have heard were regarding problems with not tightening them properly, which can happen with OEM wheels also. The reproduction wheels (Western?) had thicker spokes and are discernable from OEM, although I heard something last year about some reproduction wheels with thinner spokes.
Paul- Top
Here are a couple of pictures that may help out when looking at the wheels. You will want the long nuts to locate the adapters correctly.- Top
- Top
That is the way I understood it, that 67 s were bolt on. Very enlightening information guys, I appreciate it very much. I didn't get a chance to go look at the wheels today, but when I do, I'll update yall as to what he has. Thx, JC- Top
John, another easy way to know if the wheels are reproduction vs. original is the anti-theft "safety" pin on the aftermarket wheels. If the wheels that you are looking to buy have small half-round slots in the wheels and hubs, then they are not original. The aftermarket companies installed several of these slots on both the wheel and the hub adapter so the wheel could be tightened until two half-round slots aligned and created a full circular slot. Then, an aluminum safety pin (sold by most vendors) could be inserted to deter theft. Some guys install steel pins (solid or roll pins) in the slot as an added safety feature to ensure/hope that a wheel doesn't come loose while driving. Not everyone agrees with that approach, but I use steel roll pins for the added peace of mind. A thin layer of anti-seize is also recommended between the wheel & adapter and on the threads of the spinner when the wheels are installed. I also put a some on the safety pins. With all that said, I would buy a new set of direct bolt-on knock-off wheels that would give you the great look of knock-offs and the security of 5 lug nuts holding the wheels on your car. No lead hammer, anti-seize, pins, and checking to make sure the wheels aren't getting loose. I use a silver Sharpie to make a small line between the spinner and cone which I check to make sure they are aligned every time before I go for a ride. Keep your original steel rims and hubcaps in your garage for judging and/or resale down the road. Or you can buy 5 new bolt-on knock-offs and trade them for my beautiful 1990 vintage Western knock-offs. Good luck, Roger (50141)
- Top
Paul- Top
'63-66 are true knockoffs but they use an adapter that bolts to the mounting flange that attaches the knockoff adapter to the wheel studs where the steel wheels would bolt to.Bill Clupper #618- Top
JC- Top
John,
Here are some Western reproduction KO's I bought in the early 80's. Obviously the color is all wrong but fins are pretty close to the KH. Also notice the adapter in the last shot. The Right side will have grooves cut in the threads for pins. Original will NOT have the grooves.
One thing you might consider is buying a set of either bolt-on reproductions or (repo) knock offs and mounting some nice radials on them for diving and save your steel wheel with bias ply and hub caps for judging. You get the best of both worlds. If I decided to have my car judged that's what I will do. Keep in mind a minty set of 5 original K-H knock offs could exceed $10K.
Mike- Top
John
Be careful about "I ran across a guy who has a set of new OEM knock-off wheels and these are the real deal as I understand it. ". These could be service parts and dated well after 1965. 1964 and early 65 wheels had ink stamped date codes. Late 65 and after had them stamped into the rim backside. This is picked up on the spare when being judged.
Phil- Top
John,
Here are some Western reproduction KO's I bought in the early 80's. Obviously the color is all wrong but fins are pretty close to the KH. Also notice the adapter in the last shot. The Right side will have grooves cut in the threads for pins. Original will NOT have the grooves.- Top
