headlight ball housings - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    looking for the correct color or finish for the headlamp supports (ball housings )on my 65 .so far I have tried glass beading , to light . wire brushing , to shiny . what I believe looks good was glass beading the heavy corrosion off then using a fine wire brush on my bench grinder leaving it smooth but to shiny then dipping in acid . That gave them a slightly dark smooth finish . What is the correct color ?
  • David H.
    • December 1, 1996
    • 241
    Re: headlight ball housings
    The same as the motor gearbox housing. I have some nos ones from 1983 I will take a picture of them and compare to some used ones. Davidimage.jpg
    • Bill W.
      • March 1, 1980
      • 2000
      Thanks Dave my finished product looks just like your photo .
      • David H.
        • December 1, 1996
        • 241
        Remember that one is old so surely tarnished from new. You have the right idea with bead blasting but watch your head size 220 works good. I mix and some walnut shells just to soften the bead blasting process. And then the fine wire wheel will finish it.
