Usefull Info on 63-67 H/L Motors - NCRS Discussion Boards
  • William L.
    • December 1, 1988
    • 944
    I restore a lot of 63-67 Headlight Motors and I have recently seen a rash of folks using the wrong length bolt for the mount bracket/grounding wire. This 10-24 bolt should be 3/8" in length. Any longer and you run the risk of the bolt going into the field of the motor shorting it out. Picture one... Bolt to long and shorting out the field. Picture 2 correct length bolt
    Just thought I would pass this along to help save someone an expensive mistake.
    Bill
    Bill Lacy
    1998 Indy Pacecar
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Usefull Info on 63-67 H/L Motors
    Bill . Do you think one of the parts vendors are selling the wrong bolt ?
    • William L.
      • December 1, 1988
      • 944
      Could be Bill.
      Bill Lacy
      1998 Indy Pacecar
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Bill, Good info for the masses......
        Yes I found out the hard way years ago on a '63. Luckily I caught it in time and just scraped the shellac of the field winding a bit. No permanent damage.
        The last ones I got from Zip were correct length. #HDL-280
        Rich
