Hoping to get some input RE a puzzling problem.
Car specs:
L36 AC Coupe
57k original miles
Standard ignition
Bone stock... runs like a sewing machine (when it's running!)
The car has run flawlessly for the 12 years I've owned it. Until yesterday; I drove 35 miles from Seattle to Everett WA with no problem. On my return, about 30 miles into the trip back home, the engine cut out. Died. Kaput. It was like the ignition was turned off - no spark. I coasted across 2 lanes to the side of the freeway. All the other electricals worked fine (radio, lights, signals, etc). I let it sit for 5 min, then it started back up. I idled/revved it for a couple minutes, then as I was about to go, it cut out again. I had a buddy look at the carb - and it was squirting fuel - so it's not a fuel delivery issue. I made sure the coil wasn't grounding on the ignition shielding - nope. Over a30 min. period It'd start, then die again.
At that point, I called Hagerty and had the car flat-bedded home. When I got there, I rolled off the truck, started it and drove into the garage onto the 4-post lift. Today hoisted it up and checked-out the following:
Ignition shielding grounding coil wire - nope.
Fuse block connections - the ignition wire has already been "jumped" to fix what is a problem with AC cars.
Chased other wires around the ignition & starter to make sure I don't have a grounded or frayed wire somewhere - nada (though I'm sure they get hot)
checked the wiring on the back of the ignition switch - all looks good, solid and tight.
It appears to be an intermittent problem, so I'm hesitant to drive the car and be stranded. I feel like I need to replace any/all suspect parts. What could it be?
Coil?
Condensor?
Ballast Resistor?
Ignition switch?
Any clues for troubles hooting are appreciated... Cheers
Car specs:
L36 AC Coupe
57k original miles
Standard ignition
Coil?
Condensor?
Ballast Resistor?
Ignition switch?
