1970 convertible top caution label - NCRS Discussion Boards
  • Steven A.
    • March 29, 2009
    • 14
    The judging guide says there is a caution label "On the drivers side, just below the window" ? Could someone be a little more precise as to exactly where it should be?
    • 15573
    Re: 1970 convertible top caution label
    It is sewn into the seam at the bottom of the top below the window even with the driver's side edge of the window lower corner. It is the same location 1968 to 1974, and I believe it is the same location on mid-years -- but don't quote me on that.
    After that lucid description perhaps you can understand why there is not a more verbose description in the TIM&JG. If your convertible top supplier doesn't know where it is to be placed you might consider finding another source.
    • Lyndon S.
      • April 30, 1988
      • 1027
      If you are going to replace the top, I would go with a Al Knoch top as they can also put the date in the rear window with the correct codes for your build date.
      • Steven A.
        • March 29, 2009
        • 14
        Thanks for replying Lyndon. The top has been replaced, beautiful job with the correct date but just didn't have the "Caution label". Still having a hard time visualizing where it goes in relation to me sitting in the seat.
        • Steven A.
          • March 29, 2009
          • 14
          Thanks for your patience guys. It finally just dawned on me where you are talking about . For some reason I thought it was inside the top, not sticking outside on the lower driver side below the back window
