1954 Cylinders 3 & 4 carbon fouled - NCRS Discussion Boards
  • David W.
    • May 31, 1990
    • 51
    What might cause cylinders 3 & 4 to quickly (several miles) carbon foul, while 1,2,5 & 6 appear with normal deposits. The engine has a rough idle; does not miss on heavy acceleration.
  • Jim L.
    • September 30, 1979
    • 1805
    Re: 1954 Cylinders 3 & 4 carbon fouled
    I'd look at the middle carburetor, checking for improper float level and/or worn jet and metering rod.
    Jim
    • David W.
      • May 31, 1990
      • 51
      Thanks, Jim. I did just that...I set the float to 9/16" and installed a new needle with Viton tip, don't have a new metering rod or main jet. Know of any place they can be found??? Drove it about 10 miles on country roads, and there doesn't appear to be any fuel leaking at the air horn when I shut it off. Soon as it cools off, I'll check the # 3 & 4 plugs. Dave
      • David W.
        • May 31, 1990
        • 51
        Just pulled # 3 & # 4 Plugs...both carbon fouled. Wonder what is going on?
        • Jim L.
          • 1805
          David,
          I don't know a source of replacement jets and metering rods. When the carbs on my '54 began running rich due to wear, I was lucky enough to have a spare set of carbs with usable rods and jets.
          Been thinking about your problem some more..... something else you might explore is whether the choke plate on that center carburetor is fully open. If not, a rich condition for #3 and #4 will result.
          Jim
          • Jim L.
            • 1805
            Do you have a set of pin gages with which you can check the bores of all three jets? As little as .001 wear will significantly enrichen the air/fuel mixture.
            Similarly do you have calipers or micrometers with which you can check the diameter of the metering rod? Same comment..... it takes very little wear to alter air/fuel.
            Jim
            • Ken A.
              • July 31, 1986
              • 929
              Sounds like 2 plugs are not firing. Check ignition system thoroughly. (wires, cap, rotor & switch plugs with 2 other cylinders.)
              • David W.
                • May 31, 1990
                • 51
                It does sound like they aren't firing. I have an oscilloscope and will check to see. All new wires and cap.
                • David W.
                  • May 31, 1990
                  • 51
                  I guess I better check the size of the metering jets and the metering rods. They're old and could be worn enough to cause the problem. Thanks. Dave
                  • Jim T.
                    • March 1, 1993
                    • 5351
                    If you have some of the old wires, try them to see if it fires OK.
                    • David W.
                      • May 31, 1990
                      • 51
                      A good idea, but I don't have the old wires I did check each wire with an ohmmeter, and each one has continuity. I'll check the cap and rotor next, and then check the system with an oscilloscope for available voltage and required voltage
                      • Troy P.
                        • February 1, 1989
                        • 1279
                        Searching the web for Carter YH carb info last year I found a guy that makes the metering rods. He's not a Corvette guy but deals with all the other vehicles and boats that used the YH carb. I don't have his info handy but suspect you can duplicate my search.
                        • David W.
                          • May 31, 1990
                          • 51
                          Hi, Troy...good info. I'll look for him. Thanks
                          • Jim L.
                            • 1805
                            I found this when I searched for "carter YH metering rod":
                            Bluehost - Top rated web hosting provider - Free 1 click installs For blogs, shopping carts, and more. Get a free domain name, real NON-outsourced 24/7 support, and superior speed. web hosting provider php hosting cheap web hosting, Web hosting, domain names, front page hosting, email hosting. We offer affordable hosting, web hosting provider business web hosting, ecommerce hosting, unix hosting. Phone support available, Free Domain, and Free Setup.
                            Looks really interesting.
                            Jim
                            • David W.
                              • May 31, 1990
                              • 51
                              Hi, Jim...Yes, I was just looking at Blackhawk's web page. The tapered metering rods seem to make sense. I'll contact them.
