Does the date code on my June built 1964 roadster's List 2818 Holley 401 indicate: 1964, October, first week? Or am I reading the 0 incorrectly and it is a D for April? Thanks, Mike
Holley date code.
Tags: None
- Top
Re: Holley date code.
Mike:
There is no "D"......only A for November and B for December. All the rest are numbers only. Therefore 401 is 1964, October, First week of the month. A few months to late for being original to your car.
You can also check a few other date codes on the various carb components to see what they say......whether they agree with the date stamp on the air horn.
I believe that around 1972, Holley went to a four digit (number) Julian date code. Carbs built after this date would have four numbers.
Larry- Top
Also, with date code 1st week of October 1964, the carb model will be stamped LIST 2818-1 (ie. dash 1), which began sometime around 462 (per '65 TIM&JG) and 482 (earliest I've seen with the dash-1).- Top
Thanks to both of you. It is stamped LIST 2818-1 Looks as though the search is on for the correctly dated carb.- Top
