how to paint a 67 BB - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    thinking about this seems real easy to do. but I want to make sure I do it correctly. using this old thread as a guideline https://www.forums.ncrs.org/showthre...ight=tonawanda. I come to conclude that the exhaust manifolds, and water pump were on the engine before painting. so there for behind those items was just over-spray at best. if it makes any difference I am working on a L36 and M35 so I am to think that the distributor was installed before painting as well. so the distributor should have overs-pray as well.
    was any of the power glide linkage installed?
    how was the stamp pad masked off? also was the engine suffix label on the passenger valve cover put on after panting? I know the Tonawanda sticker was.
    I am aware of the valve cover bolts of the spark plug wires not be painted but the spreaders were.
    what else
    Re: how to paint a 67 BB
    what else
    Keith -
    The Powerglide linkage was installed at St. Louis, with the transmission. The stamp pad was masked with a piece of tape. The suffix sticker was installed after painting, but the Tonawanda label on the passenger side valve cover was applied BEFORE paint, and the top liner was peeled off after paint, exposing the mylar label surface. The painted valve cover bolts at the spark plug wire braid ground connections (on radio-equipped units) were replaced with zinc-plated bolts at St. Louis when they installed the spark plug wires; the other five bolts on each side (and all of the reinforcements) remained painted.
    • Keith B.
      • March 7, 2008
      • 928
      Thanks John. So was that thread a good guide to go by.
        Keith -
        Yes, it was. I enjoyed Mark's dissertation and photos - he does really great work!
        • Keith B.
          • March 7, 2008
          • 928
          Thanks I only want to paint this engine once. And want it to look right.
