Re: Clutch Brake Pedal Assembly
All------
The 68-81 clutch pedal design was very "regressive" design.
1963-66 used a pushrod clevis pin that was part of a bracket that was attached to the clutch pedal lever shaft with two bolts. So, replacement of the clevis pin was relatively easy, even with the pedal in the car.
1967 used a clevis pin with a bracket but the bracket was welded to the pedal lever shaft. This made replacement difficult and essentially requires removal of the pedal to replace it.
1968-81 uses just the bare clevis pin pressed into a hole in the pedal lever shaft and tack welded to the shaft. This makes replacement difficult with the pedal in the car.
All------
