about 2 years ago, i had the master cyl in a 56 vet done by a shop whose address i've misplaced(i never misplace the beast). anyway, i need a 65 mc sleeved. anybody have a favorite shop . the shop i used 2 years ago was recommended by this tdb.. thanks,mike
stainless sleeving of master/wheel cylinders
Re: stainless sleeving of master/wheel cylinders
CSSB ( The bus boys John and Luke) have done several for me DocDick Whittington- Top
My 63 was done by Brake and Equipment Warehouse in Minneapolis (612) 378-3141 (800) 233-4053. Very quick turn around, looked like a new Master Cylinder. I had them do the cleaning and install the sleeve, and I rebuild with a new kit. They charged $95 and that includes the return postage.
- Top
White Post did mine....wheel cylinders and brake master1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
For you guys that had sleeves installed.....
I had a '60 MC handed to me that was sleeved in brass. Used DOT 5 silicone fluid. BTW, last several C1/C2's I've done are DOT 5 and I'll NEVER go back to DOT 3.
When I bench bled it after a Corvette Central MC kit, it chugged(like a slightly jerky feeling) and squeaked like crazy. I thought it may have been due to using that older CC MC rebuild kit, so I took it apart again and installed a brandy new NAPA rebuild kit......Same squeaky, jerky, chugging, bench bleed. I installed on the car and bled the whole system. Brakes are fine, but I can feel & hear a slight squeakiness and jerkiness in the pedal. The more I use the brakes it appears to be getting less noticeable.
The other past DOT5 restorations didn't have this oddity, but they were brand new MC's, not sleeved.
Anybody ever notice this on their sleeved MC's?
Rich- Top
The C4 is designed to use DOT3 brake fluid in the hydraulic clutch. There used to be a special brake fluid available from GM for the clutch that eliminated squeaking as you actuated the clutch master cylinder. The squeaking as you cycle the cylinder must be a common issue....For you guys that had sleeves installed.....
Rich- Top
