I recently removed and replaced the distribution block on my '69 so now the brakes needed to be bled. In the past I have always bled brakes by the "on/off" method with my wife pressing the brake peddle while I opened and closed the bleeder. This time I wanted to try the gravity bleed method. I opened each bleeder one at a time and let the fluid flow. The question is- how do you know when the line is bled? Right from the get go I got a solid flow with no bubbles. I filled each chamber of the MC twice for each bleeder so I know a good amount of fluid passed through the pipes. Any advise?
Thanks!
Jeff
Thanks!
Jeff
