1971 Center Console Restoration - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 474
    I want to try and refinish the center console and instrument cluster and looking for any advice on refinishing them. First, what is the correct shade of black. Looks to me that it should be a bit shinier than a semi gloss but not gloss black. Any suggestions appreciated. Also, what about masking the chrome edges and lightly bead blasting the painted area or just trying to scuff it with fine steel wool or?? Any and all sugestions Greatly appreciated.
    Sheldon
  • Mike F.
    • April 25, 2011
    • 668
    Re: 1971 Center Console Restoration
    I painted mine using SEM 39143 Trim Black. I painted the entire consol, then went over the chrome with a razor/x-acto knife to remove the paint.
    • Michael D.
      • June 30, 1996
      • 536
      I used the old, original 5-ball Krylon semi-flat black. The old formula is available through industrial coatings outlets.
      • Don L.
        • August 31, 2005
        • 1005
        I did mine the same way, also using SEM Trim Black. I LOVE this paint! I used a squared off wooden coffee stirrer (thank you Starbucks) before the razor blade. Works best if you scrape the excess paint off soon after the paint dries to the touch.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Sheldon S.
          • March 1, 1999
          • 474
          How did you prep the parts for painting? Bead blast or just had sanding?
          Sheldon
            • 11608
            Sheldon
            Paint stripper and then wax & grease remover. No sanding needed.
