Intake manifold gasket replacement -adding sealant? - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 341
    Hi,
    my question doesn't specifically pertain to my Corvette but to vintage US V8 cast iron engines in general:
    Do you recommend the application of a high temperature sealant beside the intake manifold gasket, too?
    Oliver
  • Jeff P.
    • October 21, 2011
    • 287
    Re: Intake manifold gasket replacement -adding sealant?
    Oliver, I've always used Permatex at the corners of the intake gaskets where they touch the rubber gaskets to make sure they seal that area. Also rubber gaskets are twisted so i add a dab to hold them down on the surface. I've seen some mechanic's simply use silicone sealant instead of the rubber intake gaskets.
    • Bruce B.
      • May 31, 1996
      • 2930
      Many mechanics say throw away the front and rear intake manifold seals and use silicone instead of the rubber seal. NO.
      I always use the front and rear rubber seals and I hold them in place with small dabs of black silicone sealer and also put some at each end of the rubber seal where it meets the intake gaskets.
      This always results in a good seal with no oil leaks.
        Bruce-----
        GM ceased the use of rubber end seals on all small block and big block engines after 1980. For 1981 and later only formed-in-place silicone RTV was used.
        • Domenic T.
          • January 29, 2010
          • 2452
          Joe,
          I have used RTV for years after removing the old rubber ones that got hard and lost their seal and only used RTV on rebuilds. The old rubber seals were so brittle that you had to take them off in pieces.
          To stop a leak we used to re-seal the front & back without removing the manifold. We would make a hook and remove the old hard rubber seal, clean the block & manifold with a solvent, then squeeze the RTV where the old seal was and let it cure.
          DOM
          I can see why some use the rubber because of judging. To bad they don't make them out of something that would stay soft & keep the seal.
          DOM
            Originally posted by Domenic Tallarita (51287)
            Joe,
            DOM
            DOM
            Dom-----
            Heat is the culprit in the hardening and failure of these rubber end seals. If they made them out of high temp silicone rubber they would probably last. But, they don't. The high temp silicone RTV which GM specified for the end seals post 1980 remains pliable and brittle-free at temperatures far higher than it will ever see in the manifold end seal application.
            I use Permatex Ultra Copper or Ultra Black.
            One other thing I should have mentioned: the rubber seals are designed for a specific and narrow range of gap between the intake manifold and block bulkheads. However, this gap can vary beyond PRODUCTION tolerances due to SERVICE machining of the cylinder head deck, block deck, or intake manifold. If the resultant gap is too small, the rubber gaskets will over-compress, break, and "squeeze out". If the gap is too large, there will not be sufficient compression on the seal to effect a good seal. With RTV the size of the gap is essentially irrelevant. With RTV, properly applied, you can get a perfect seal every time.
              • 15573
              Dom-----
              The key Joe, is the words properly applied. At the engine plants a machine dispensed a measured quantity at a specific thickness to a properly cleaned location. Then the intake manifold was lowered straight down into place. Good luck doing all that in your garage.
              BTW: The RTV rear end seal on GenII LT1s suffers from temperature failure near the passenger side due to the proximity of the EGR tube coming from the passenger side exhaust manifold. To my knowledge there is no permanent cure. Re-sealing the intake is an ongoing maintenance task for these engines.
              • Dale O.
                • May 31, 1995
                • 52
                Joe or Terry do you know what the gap should be between the block and intake on a chevy small block and big block?
                  • 15573
                  Sorry Dale, I do not.
                    Dale-----
                    I once knew but I've long-since forgotten. I have a habit of not writing things down and relying on my memory. That doesn't always work, though.
                    • Martin M.
                      • November 1, 1979
                      • 124
                      Joe, I suspect your memory is full!!
                      Beautiful Pahrump, NV.
                      No smog, no rain, no winter, no hurricanes, no tornadoes,
                      no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
                      vetteheads.com alumni, Boston MA alumni
                      1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
                      1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
                      1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
                      1957 Chrysler 300 C 392 Hemi Car
                      All for sale - most not cheap!!!
                        Marty-----
                        Yes, I need to start deleting stuff so I can get new stuff in.
                        • Bill H.
                          • August 8, 2011
                          • 439
                          I quit using Permatex's Ultras years ago after they came out with "The Right Stuff". It's so much better than RTV.
                          • Timothy B.
                            • April 30, 1983
                            • 5177
                            Marty-----
                            Joe,
                            That happens naturally, don't rush it. :-)
                            • Martin M.
                              • November 1, 1979
                              • 124
                              I have used "The right stuff" many times. I find it to be an excellent product.
