1954 Carter YH leak-down - NCRS Discussion Boards
  • David W.
    • May 31, 1990
    • 51
    I'm sure this question has been asked and answered many times in the past, but searching the posts, I can't find any reference.
    Question is, "Why do the YH carburetor fuel bowls on my 1954 leak down after sitting for a week or so?" And where does the fuel go? Also, is there a "fix' for this problem?
    Dave
  • Daniel S.
    • February 1, 2000
    • 164
    Re: 1954 Carter YH leak-down
    Fuel is most likely evaporating after the car sits that long
      • 6940
      Dave, Dan is likely right, but there is one check you can do, Is after the car is shut down for a few minutes is take a peek into the carb. and look to see if there is anything dripping or fuel vapors hanging around in the lower throttle body area of carb. If you live in a area that has ethanol in the fuel it seems to evaporate quickly after sitting.
      • David W.
        • May 31, 1990
        • 51
        Thanks, Dan...guess I should run the car more often, but in the Midwest this time of year with the top stored....it's kinda chilly. I don't like to just start the engine and idle it for a while...I believe it takes 10 miles or so before all the moisture is dried up.
        • David W.
          • May 31, 1990
          • 51
          Hi, Ed...The front two are dry after shutdown; the rear did drip a bit. We do have ethanol in the fuel around here. Guess I should drive the car more frequently, but it gets kinda chilly here this time of year Thanks for the info.
