I bought a 7028209 quadrajet for my 68 several years ago only to find out that it had the small block choke linkage on it. Recently I came across what I believe is the correct linkage and am trying to figure out how it connects to the manifold coil. I purchased the link rod, coil, and cover years ago from one of the suppliers that was supposedly correct for the 68 big block. As you can see from the pictures the coil and linkage to the choke arm on the carb connect well and if I apply heat to the coil, the choke works as it is supposed to. The problem is that the cover has the cutout for the link rod to exit on the inboard side. When I try to position the link rod on the inside so that it would exit through the cover, it fits poorly and binds. I am thinking that perhaps there was a different cover for the big blocks or that the coil and link that I bought are wrong, even though it seems like they will work. Does anyone with a 68 427 have some good pictures of choke linkage that might help me figure out how this is to go together?
John
John
