C2 Fan Clutch - NCRS Discussion Boards
C2 Fan Clutch
  • Donald H.
    • November 2, 2009
    • 2580
    Re: C2 Fan Clutch
    sorry,
    Forget this post, I did catch Dave's comments above.
    Can anyone comment on the one I pictured in post #12. Does it look correct for 66?
    Did the part numbers change from late C1s to C2s?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • David L.
      • July 31, 1980
      • 3310
      Re: C2 Fan Clutch
      Originally posted by Donald Harris (51003)
      I found another one on Ebay that is listed as a 61 fan clutch. No apparent stamping on the face. Were the fan clutches the same for late C1s and C2s?
      I know there is a difference in small block and big block, i.e. measurement from the mounting flange to the base of the bolts (boss) where the blade mounts.
      How does this one look.
      [ATTACH=CONFIG]48861[/ATTACH]
      Don,
      The 5-blade fan appears to be GM # 3789562, an 18" dia. fan with 4 rivets/blade and was used on 66-67 Corvettes w/AC & 64-67 Chevrolets w/AC.
      The 5-blade 18" dia fan used on 58-63 Chevrolets has 5 domed rivets/blade, GM # 3749576.
      The clutch appears to be the Eaton type used on 63-67 Chevrolets & Corvettes.
      Dave
      • Donald H.
        • November 2, 2009
        • 2580
        #18
        Re: C2 Fan Clutch
        Originally posted by David Liukkonen (3775)
        Don,
        Dave
        I'll keep an eye on it.
        Don Harris
