I have four axel shafts that appear to be the same except for the diameter for one pair is approximately 3/4" bigger than the smaller ones. I can't find any numbers so is there a way to confirm the years they were made and are the larger ones usable on a non-matching number C2? Thanks, jb
C2/c3 axel shafts
Re: C2/c3 axel shafts
Jim. Are you referring to the 1/2 shafts or the differential inner axles? The 1/2 shafts should be the same for 63-79 to my knowledge, the diameter did change in '75 (2.5" to 3")but the length and joint size(1350) were the same. Some of the aftermarket shaft were made wrong and resulted in positive camber a few years ago, I think that was addressed though. Many think the 2.5's are weak and buy 3" or new aftermarket but they were strong enough and had a thicker wall tubing then the new ones on the market do.- Top
It's a Gary describes. The 2-1/2" half shafts were used from 1963-74. The 3" half shafts were used from 1975-82. The half shafts can be used interchangeably. In fact, the 3" half shafts became SERVICE for 63-74 after about 1976.
I believe the 2-1/2" half shafts were of GM internal manufacture. The 3" half shafts were manufactured by Spicer.In Appreciation of John Hinckley- Top
Gary and Joe, Thanks so much for your responses as I just got back a spare differential that I had rebuilt and will include all new u-joints with the installation on my '63. Since the larger 1/2 shafts will interchange, I can put the new u-joints in those first as they are also spares. I thought they would fit but appreciate your confirmation before I installed the new parts. Do you recommend any particular u-joint removal tool as these are older and more challenging than any I've swapped before? Thanks again- Top
