Restoring TI in my '67 L71 - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7073
    Re: Restoring TI in my '67 L71
    Thanks, he is the one I will use then, when I get the time to get it done.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Originally posted by Michael Funk (22104)
      Duke is 100% right, only real difference in dist what he states, I have points in mine as easy to start and check problems after motor rebuild and body off, you also need ti box and the warning harness has special wire which is not used when points used. contact dave as stated, he is the man. good luck
      Dave is excellent. My first TI experience on a 67 L71 a few years ago gave me much trouble. Dave spent time on the phone with me after troubleshooting for a while. His website has great tips and diagnosis flowcharts to help.
      Originally posted by Al Burton (59508)
      Mike
      I have the same issue with my 67 L68 It looks like the TI pak, & wiring harness are gone. Someone attached an after market TI amp on the fire wall with it's own harness, all of which I'd like to replace, not sure about the coil. How did you restoration back to orginal go?
      Al Burton
      Al, as mentioned above, I reinstalled a disabled TI system in a L71. The original TI amp box with it's broken internals were still mounted on the front inner skirt, but missing TI harness and TI distributor. I restored the TI module, installed a new K&B Amplifier board, got a M&H repro TI harness, and we found a correct TI distributor right out of a Driveline ad. It was like brand new, had a near perfect ID tag, and was even dated just right for the car built. It had a bad connection in the wiring of the internal pickup coil but I repaired it.
      The prior owner removed the original 435HP engine years ago, tired of broken valve springs and eventually destroyed the engine. He installed a 283 from a '64 Chevelle, and had a points distributor. He mounted his ballast resistor on a existing stud on the firewall and didn't drill out the dimple where normal production mounted it.
      I restored the car, owner acquired a correct block and tripower and restored the powertrain to original appearance. That TI system with the K&B amp is great. When you turn the key the engine JUMPS to life in about a millisecond. Great system when it's running at peak performance too.
      If you don't have a TI distributor, that will be a high cost item. Ours cost around $1000 IIRC. I haven't scoped prices lately. K&B amps are sold by many vendors. I get mine through Zip Corvette.
      Below a few pics of the pieces before and after. I highly recommend using the K&B amplifier. Not only are they great products, they carry a LIFETIME warranty. It doesn't get much better. http://kandbcorvetteproducts.com/corvette/ignition/
      Rich
      • Al B.
        • January 29, 2014
        • 22
        #18
        Thanks Mike
        As you said Its not easy and not cheap either. Something I hope to do when the weather warms up.
