Eliminating paint bubbles possibly due to brake fluid - NCRS Discussion Boards
  • Bruce W.
    • October 29, 2013
    • 1
    My 1966 convertible is getting a new paint job this winter. It has bubbles in the old paint by the master cylinder which I have been told is due to brake fluid leaching through the fiberglass. How can this be eliminated so it won't come through the new paint?
  • Cathy S.
    • August 31, 2003
    • 293
    Re: Eliminating paint bubbles possibly due to brake fluid
    Good luck!
    • Bill W.
      • March 1, 1980
      • 2000
      Try sanding the bare fiberglass with 80 grit the soak it with dupont 3812 reducer let it dry soak it again with dawn rinse and put in the sun . if there is no hot sun I use a small one bulb tanning lamp with a "new" uv bulb . If you can get to the underside make sure there is nothing wicking up . The sun is the most important part .
      • Robert M.
        • January 1, 1992
        • 78
        With my car I did what Brian said but I also placed a piece of paper towel over the area and heated the glass up with a heat gun, this pulled the remaining brake fluid out of the pores of the fiberglassand then I sprayed the car with gelcoat before priming and painting.
        • Jim T.
          • March 1, 1993
          • 5351
          Would this procedure also work for air conditioning throw off oil getting on the underside of the hood and ruining a paint job?
          • Bill W.
            • March 1, 1980
            • 2000
            Jim over the years I have used this method on some pretty nasty looking stuff with good results . It is at least worth a try . All bubbles are brought up by the sun . you need to make sure the underside is clean and wick them out before primer and paint .
