I'm changing out the rear brake rotors on my 92. The FSM states that when reinstalling the rear break caliper bracket to use new mounting bolts. The mounting bolt is gm part 14084053 but apparently it has been discontinued - I can't find new ones anywhere. First, does anyone know where I might be able to obtain 4 of these bolts new (ideally along with the washers), but secondly is it absolutely necessary to reinstall the bracket with new bolts? At this point I'm inclined to clean the bolts well and reinstall with loctite to the specified torque.
Jeff Zachwieja
58610
Jeff Zachwieja
58610
