C2 Washer Nozzle - NCRS Discussion Boards
C2 Washer Nozzle
  • Daniel E.
    • April 30, 2005
    • 145
    C2 Washer Nozzle
    All,
    Is this the opaque/off-white that is expected of an original washer nozzle?
    Daniel
  • Alan D.
    • January 1, 2005
    • 2027
    Re: C2 Washer Nozzle
    Here is the difference, ie original v repo
    • Gene M.
      • April 1, 1985
      • 4232
      The only thing here is the original has aged. Originals were a natural resin. Where as the repops are a pigmented white. Originals were not pigmented, a dead give-a-way.
      • Daniel E.
        • April 30, 2005
        • 145
        Thanks!
        It is an obvious color difference. What is the original part from? My mid-years have a two piece nozzle.
        Daniel
          Originally posted by Daniel Edmond (43962)
          Thanks!
          Daniel
          Daniel -
          The washer pump outlet IS two pieces - the bottom piece (valve body) contains the poppet check valves, and the top piece (outlet) has three ports - one large (inlet from the reservoir) and two smaller (outlets to the nozzles). That "sandwich" attaches to the pump housing with four screws.
            • May 31, 1974
            • 8365
            john: to my knowledge, the 63 and 64 vet pump outlet is a one piece critter. 65 thru 67 were two piece. alan's photo, on the left side, is what i believe to be a one piece 63-64 outlet(distribution block?). regards, mike
            • Brian T.
              • September 30, 1990
              • 188
              Yes, the 63-64 part was made by Rochester, and it was semi transparent with the check valves and metal seats for the valve installed. The 65-67 was a Trico part and it was an off white part as pictured in John's attachment.
              Brian
                Mike -
                Yup, should have clarified in my post that the photo was '65-up.
