Hotronics Battery Disconnect - NCRS Discussion Boards
  • Steve V.
    • June 27, 2011
    • 95
    I'm looking for a way to protect my 60 from wiring shorts, battery bleed down and possibly theft. Hotronics makes a latching type relay that goes between the battery hot cable and the starter. http://hotronicsproducts.com It doesn't require any power to maintain it's on or off position and completely disconnects power from the car. Does anybody have any experience with this or a different system?
    Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Hotronics Battery Disconnect
    Steve,
    I tend to think simpler is better. What's wrong with regular old blade type disconnect? They're available at NAPA (and I'm sure elsewhere) for around 40 bucks the last time I checked.
    Joe
    • Steve L.
      • June 30, 2001
      • 763
      It looks like a good idea, but I don't know where you would mount it on a C3 and keep it hidden without cutting the original battery cable. The link doesn't say anything about being weather proof.
      Steve L
      73 coupe since new
      Capital Corvette Club
      Ottawa, Canada
      • Jim L.
        • September 30, 1979
        • 1805
        WirthCo 20148 knife switch, MADE IN USA, and available from Amazon for $24.
        I have one on my '60.
        Jim
        • Steve V.
          • June 27, 2011
          • 95
          I inquired about the weatherproof quality of the unit and this is the answer I received.
          "Hello Steve, Thank you for your interest in Hotronics Products.
          The Battery Disconnect is not completely water proof, it's best to install inside the frame rail if your placing under the car,
          It is 'Electrical/mechanical' and not intended for Marine use. Water can enter around body & top.
          The toggle switch is sealed around wiring, however the batt handle has no O' ring for water seal. Try a small 'party" balloon to place over the toggle switch and place the battery disconnect solenoid inside a "Tupperware" container to the lid and snap the bottom over the disconnect for servicing. That's a suggestion for water-proofing.
          This is a super popular part and has been extremely reliable for thousands of rodders and has a 20 year track record in the Streetrod industry.
          Let me know if you have any other needs Steve. i'll try and answer all your questions.
          Greg"
          I like the idea of being able to activate the disconnect without opening the hood in public. The knife switch is more reliable just inconvenient.
          Decisions, decisions,
          Steve
          Thomas Edison
          • Jim D.
            • 2882
            Many of my "Hot Rod" builder buddy's use them with no issue. If mounted on the firewall, there would be no problem. It's basically a latching Ford solenoid, which in my opinion, is far superior to the GM design.
            • John F.
              • March 23, 2008
              • 2395
              Simple is better!
              • Joe R.
                • May 31, 2006
                • 1822
                Steve,
                I glanced briefly at the web site, I don't think it covered the question I would have, which would be: Can the disconnect fail in such a way that you can't power the vehicle?
                Joe
                • Robert S.
                  • May 31, 1988
                  • 81
                  Steve, just do what I do on my 60. Leave the positive terminal loose and twist it on the battery post to use the car. When not using the car twist the cable off and park it on the battery hold down bolt. Just as easy as a knife switch and 34 to 40 dollars cheaper.
