4 speed serial numbers ? - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    At what point in the assembly line did the 1965 4 speeds get the vin stamp ? Was it the same stamp and holder that was used on the block (BB) ?
    Re: 4 speed serial numbers ?
    Bill -
    The transmission was VIN-stamped right after it was bolted to the engine, early on the Engine Dress Line; until about November, the same gang-holder was used for the VIN derivative on both the engine pad and the transmission. In November, the format for the transmission stamp changed ("S" replaced the leading "5"), so there were two different gang holders for the rest of the model year.
    • Bill W.
      • March 1, 1980
      • 2000
      Thanks John .
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's an example of John's explanation. My car, St. Louis D6 trim tag, produced the first day after the strike was over. I'm guessing that the engine/trans was somewhere on the dresss line, and the new rules applied in November, although the first stamp (on the left) may have occured the last working day before the strike (Sept 25th ?).
        P.S. the assembly stamping is P0916.
        I must add that I've seen a 510137x, with the 5 overstamped with an "S" of larger font. When this would have occured, I don't know.
        z
        • Jim D.
          • 2882
          Mine was over stamped as well. The number alignment/mis-alignment is exactly the same as the engine pad so there was definitely only one gang holder used on my car.
          • Ronald C.
            • March 1, 2002
            • 77
            anyone have a good road map as to where the vin stamp is on the transmission. mine is installed in the car but I cant locate it. I thought it was on the drivers side but can it be seen with the trans in and the shift levers installed?
            • Wayne M.
              • March 1, 1980
              • 6414
              Here's the stamp on the 2nd-to-last 1965 Corvette. The view is looking up from the ground; you can see the edge of the sidecover, on the drivers side, at the bottom of the pic.
              • Loren L.
                • April 30, 1976
                • 4104
                For a car that's been sitting in a barn for 25+ years, old "563" gets a lotta press.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  And to think we still haven't mentioned the 3858174 "HF" block .
