I have two GM boxes with cushions I cant Id first is group 7.545 # 3831586 second is 9.023 # 3788637 ? Thanks .
rubber cushion Id help
Re: rubber cushion Id help
Bill------
The GM #3831586 is the rear spring end bolt cushion applicable to 1963-82 Corvettes.
The GM #3788637 is the UPPER differential "snubber" mount (cushion) applicable to 1963-79 Corvettes.
Both parts remain available from GM to this very day, 50 years after they were first released.In Appreciation of John Hinckley- Top
Bill------
Once-upon-a-time you could buy that unit of parts (i.e. bolt, nut, cushions, inner and outer retainers) from GM under GM #14029851.In Appreciation of John Hinckley- Top
