FYI,Just public service announcement for those of you with original 63-79 vettes, primarily the 63-68's which are prone to cracking the posi cases, GM is no longer stocking new bare cases. I would say 80% of the 63-68 diff's I get in have cracked posi's in them. The only options now will be using a new loaded posi, I would only use the bare case not the internals on these or try to find a good used posi case. You really have to check the used ones as well to be sure they are not cracked.Here is what you want.
