Below is clear evidence of what happens when speedometer or tachometer cables are over lubricated or lubricated with improper materials.
I received this 1967 cluster from a friend. He said the speedometer gets stuck at various speeds and won't return to zero. It's a speed minder speedometer so I thought that function was possibly jammed. I had never worked on a speed minder unit before so I was uncertain what to expect, as well as parts availability.
What I found was a totally grease encased speedometer cup and gearbox. Because the grease was so thick and aged, it lightly jammed up the rotating needle shaft cup and magnetic main shaft.
I am convinced this was caused by cable overlubrication over time, and likely using a chassis grease or possibly even a grease gun at the transmission end of the speedo cable by a prior owner or technician. I've never seen one this bad.
Proof of what happens if the cable is lubricated improperly. It took me about a hour to dissassemble and using my parts washer, spray cleaners, brushes, q-tips and various pick tools, to clean all of the grease and embedded dirt away from everthing, and then reassemble and test the speedometer. The grease was so thick and gooey it took a fine wire brush to clean it out of the gear teeth.
After cleanig and reassembly the unit worked flawlessly. I even learned how to fix the speed minder function that wasn't working properly. Interesting little mechanism that is.
Lubricate cables wisely. Use a light lubricant specifically made for these cable systems. Never use grease.
Rich
Rich
